We keep seeing below error message on our Word Invantive add-in event logs, Trying to understand and find a way to resolve the issue.
: itgentln007: Translation store is completely empty. Translation of key ‘itgen_database’ will not work.
What release does it concern?
Please make sure you are running release 22.0.
Thank you. This version is no longer supported. Recommendation is to upgrade to a supported version such as 22.0. It can be downloaded from:
