Na het aanklikken van ‘Alle administraties’ in Invantive Control 20.2.198 gebeurt er, in ieder geval visueel, niets.
Voor de formules die onder de wel geselecteerde administratie moeten worden berekend komt de volgende melding naar boven voor een fors aantal cellen:
excel-2146233088: itgenude021: Reporting scheme code invalid type for division '814xxx'.
Bericht ID: fb9396a7-c83d-4e62-b054-284bb0394f73
Opgetreden (UTC): 04-01-22 15:34:41
ValidationException
Invantive.Producer.Control.I_EOL_BAL_PDE_CLOSE_CLASSIFICATION
En deze:
itgenicr017: Onbekende tabel '[ExactOnlineREST.Financial.GLSchemes]'. Mogelijke geldige alternatieven: CONTROL.DataDictionary.UDFMeasurements, CONTROL.DataDictionary.UDFMeasurements, UDFMeasurements, UDFMeasurements.
Bericht ID: 89a842a4-65e1-4892-8e53-d29af2e70e41
Opgetreden (UTC): 04-01-22 15:27:09
ValidationException
bij Invantive.Basics.ValidationException..ctor(GlobalState owner, ExecutionOptions executionOptions, String messageCode, String messageText, String kindRequest, String localStackTrace, String nk, Exception innerException, Boolean inheritMessageCodeWhenPresent, Nullable`1 uid, Boolean isRecoverable, String poolIdentityId, String url)
bij Invantive.Producer.Control.Provider.InvantiveControlProvider.GetObjectMetadata(GlobalState owner, ExecutionOptions executionOptions, ObjectSpecification objectSpecification, Boolean raiseErrorIfNotFound)
bij Invantive.Producer.Control.Provider.InvantiveControlProvider.GetObjectMetadata(GlobalState owner, ExecutionOptions executionOptions, String objectName, Boolean raiseErrorIfNotFound)
bij Invantive.Data.ConnectionManager.HR(GlobalState , ExecutionOptions , String , Boolean )
bij Invantive.Data.ConnectionManager.GetObjectMetadata(GlobalState owner, ExecutionOptions executionOptions, String escapedAndFullQualifiedName, Boolean raiseErrorIfNotFound)
bij Invantive.Data.ConnectionManager.GetObjectMetadata(GlobalState owner, ExecutionOptions executionOptions, String escapedAndFullQualifiedName)
bij Invantive.Data.DataUtility.GetEntityFieldsOfTable(GlobalState owner, ExecutionOptions executionOptions, IProviderManager manager, String fullQualifiedTableName)
bij Invantive.Producer.Control.UdfExactOnline.GetEolRestReportingSchemeInformation(GlobalState owner, ExecutionOptions executionOptions, String fieldName, String divisionCode, String code, Boolean useMain, String executionHint, Boolean isNoValueNA, ResultAggregationMethod resultAggregationMethod)
bij Invantive.Producer.Control.UdfHub.GetEolRestReportingSchemeInformation(String fieldName, String divisionCode, String code, Boolean useMain, String executionHint, Boolean isNoValueNA, ResultAggregationMethod resultAggregationMethod)
bij Invantive.Producer.Control.UdfExactOnline.GetEolRestMainReportingSchemeCode(GlobalState owner, ExecutionOptions executionOptions, String divisionCode, String reportingSchemeCode, String executionHint)
bij Invantive.Producer.Control.UdfHub.GetEolRestMainReportingSchemeCode(String divisionCode, String reportingSchemeCode, String executionHint, Boolean preventWriteToMeasurementLog)
bij Invantive.Producer.Control.UdfHub.N(GlobalState , ExecutionOptions , String , String , String )
bij Invantive.Producer.Control.UdfHub.GetEolXmlBalanceLinePeriodInformation(String fieldName, String divisionCode, Int64 reportingYear, Int64 reportingPeriodFrom, Int64 reportingPeriodTo, String glAccountCode, String glAccountType, String glAccountBalanceType, String reportingSchemeCode, String classificationCode, Boolean afterEntry, Int64 classificationLevelsIncluded, String executionHint, Boolean isNoValueNA, ResultAggregationMethod resultAggregationMethod)
bij System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
bij System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
bij System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
bij Invantive.Producer.Control.Provider.InvantiveControlProvider.GetObjectMetadata(GlobalState owner, ExecutionOptions executionOptions, ObjectSpecification objectSpecification, Boolean raiseErrorIfNotFound) in Invantive.Control\src\Invantive.Producer.Control\Properties\Resources.Designer.cs:regel 301
bij Invantive.Producer.Control.Provider.InvantiveControlProvider.GetObjectMetadata(GlobalState owner, ExecutionOptions executionOptions, String objectName, Boolean raiseErrorIfNotFound) in Invantive.Control\src\Invantive.Producer.Control\Properties\Resources.Designer.cs:regel 289
bij Invantive.Producer.Control.UdfExactOnline.GetEolRestReportingSchemeInformation(GlobalState owner, ExecutionOptions executionOptions, String fieldName, String divisionCode, String code, Boolean useMain, String executionHint, Boolean isNoValueNA, ResultAggregationMethod resultAggregationMethod) in Invantive.Control\src\Invantive.Producer.Control\UDF\Platforms\UdfExactOnline.cs:regel 7466
Enig idee wat hier aan de hand is?
