Ik krijg sinds een aantal dagen onderstaande errormelding wanneer ik vanuit Teamleader de v1 deals probeer te syncen. Onderstaand de code die uitgevoerd wordt, en daaronder de errormelding.
Enig idee waar dit aan kan liggen? (zie ook de error helemaal onderaan)
SQL-code
local on error continue
local define AANTAL_SLOTS “5”
local define SLOT_SIZE “7”
local define DAYS_UPDATE “7”
select to_char(trunc(sysdateutc) - ${DAYS_UPDATE}, ‘YYYYMMDD’)
local define WATERSHED_DATE “${outcome:0,0}”
create or replace table deals@inmemorystorage
from teamleader.v1.deals@tl delcreate or replace table dealsnew@inmemorystorage
from deals@inmemorystorage del
where del.latest_activity_date >= to_date(‘${WATERSHED_DATE}’, ‘YYYYMMDD’)create or replace table deals_soll@inmemorystorage
select del.id
, deld.*
from dealsnew@inmemorystorage del
join teamleader.v1.deal(del.id)@tl deldsynchronize tl1_deals@sqlserver
from deals_soll@inmemorystorage
with insert
or
update all except rowid$
identified
by id
Errorlog
2021-08-18 09:57:30.747 Information itgendhb044: Run SQL statement: synchronize tl1_deals@sqlserver
with insert
or
identified
by id
2021-08-18 09:57:30.749 Information itgensql264: itgen_invantive_sql_statement_started_dot
2021-08-18 09:57:39.435 Warning itgendhb173: itgen_context: C:\jobs\sql\replicate.test.4.sql: synchronize tl1_deals@sqlserver from deals_soll@inmemor… update all except rowid$ identified by id
2021-08-18 09:57:39.505 Error itgencun016: Error itgenclr096: itgenclr096: Multiple errors in Invantive Data Hub.
One or more errors occurred.
Incorrect syntax near the keyword ‘for’.
2021-08-18 09:57:41.515 Error itgenclr096: System.Data.SqlClient.SqlException
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Boolean shouldCacheForAlwaysEncrypted) at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest) at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at Invantive.Data.AnsiSqlProviderBase.PassthroughSqlAction(GlobalState owner, ExecutionOptions executionOptions, String actionSql, ParameterList parameterList, String loggingTableName) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at Invantive.Data.AnsiSqlProviderBase.PassthroughSqlAction(GlobalState owner, ExecutionOptions executionOptions, String actionSql, ParameterList parameterList, String loggingTableName) at Invantive.Data.AnsiSqlProviderBase.Update(GlobalState owner, ExecutionOptions executionOptions, EntityFieldCollection entityFields, QueryObject queryObject, ParameterList parameterValues, ResultSet sourceContext) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at Invantive.Data.AnsiSqlProviderBase.Update(GlobalState owner, ExecutionOptions executionOptions, EntityFieldCollection entityFields, QueryObject queryObject, ParameterList parameterValues, ResultSet sourceContext) at Invantive.Sql.SynchronizeStatementTree.<Synchronize>d__72.MoveNext() System.Data.SqlClient.SqlException at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action1 wrapCloseInAction)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
— End of stack trace from previous location where exception was thrown —
at Invantive.Sql.SynchronizeStatementTree.d__72.MoveNext()
System.AggregateException
ValidationException
at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
Kan het wellicht iets te maken hebben met onderstaande errormelding? Deze komt voor bij het opstarten van de datahub v20.0
2021-08-18 09:55:13.722 Error itgencun016: Exclamation itgenclr068: Could not load file or assembly ‘System.Numerics.Vectors, Version=4.1.3.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’ or one of its dependencies. The located assembly’s manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040).
2021-08-18 09:55:13.736 Error itgencun017: System.IO.FileLoadException
at System.SpanHelpers.IndexOf(Byte& searchSpace, Byte value, Int32 length)
at System.Text.Json.Utf8JsonReader.ConsumeStringAndValidate(ReadOnlySpan`1 data, Int32 idx)
at System.Text.Json.Utf8JsonReader.ConsumeString()
at System.Text.Json.Utf8JsonReader.ConsumeValue(Byte marker)
at System.Text.Json.Utf8JsonReader.ReadSingleSegment()
at System.Text.Json.Utf8JsonReader.Read()
at System.Text.Json.JsonSerializer.ReadCore(JsonSerializerOptions options, Utf8JsonReader& reader, ReadStack& readStack)
at System.Text.Json.JsonSerializer.ReadCore(Type returnType, JsonSerializerOptions options, Utf8JsonReader& reader)
at System.Text.Json.JsonSerializer.Deserialize(String json, Type returnType, JsonSerializerOptions options)
at System.Text.Json.JsonSerializer.Deserialize[TValue](String json, JsonSerializerOptions options)
at Invantive.Data.TranslationStore.FT(GlobalState , ExecutionOptions , String , String , String , Boolean )
at Invantive.Data.TranslationStore.Read(GlobalState owner, ExecutionOptions executionOptions, String text, String expectedLanguageCode, String originatingFileName)
at Invantive.Data.TranslationStore.LoadTranslations(GlobalState owner, ExecutionOptions executionOptions, String fileName, String expectedLanguageCode)
at Invantive.Data.DataContextBase.LoadTranslations(GlobalState owner, ExecutionOptions executionOptions, String translationStoreFileLocation, String expectedLanguageCode)
at Invantive.Producer.UtilityBaseCore.CreateAndLoadTranslations(GlobalState owner, ExecutionOptions executionOptions, String languageCode)
at Invantive.Producer.UtilityBaseCore.Initialize(GlobalState owner, ExecutionOptions executionOptions)
