The overnight refreshes keep failing with the same error as mentioned in this post.
Request id : 0HN2JAPT37HVJ:00000013
Het verzoek met request ID is inderdaad meteen afgebroken binnen enkele milliseconden (itgenclr150, die leidt tot itgenboe367).
Het is niet gelukt om de oorzaak te vinden; meestal ligt die in de tijd er voor.
De omgeving is herstart. Gelieve nogmaals te proberen.
The refreshes fail.
0HN2M20PQC7IL:0000004B (HTTP/2)
It’s been broken for over 2 weeks, which blocks the work of our Finance team.
Data source error[ValidateMarkupTags][ccon]DataSource.Error:
[ccon]OData[/ccon]:
Request failed:
[ccon]The underlying connection was closed:
An unexpected error occurred on a receive.[/ccon].
DataSourceKind = [ccon]OData[/ccon].
DataSourcePath = [ccon]https://bridge-online.cloud/acme-exact-online/odata4/ExactOnlineREST.Incremental.TransactionLinesIncremental@eol[/ccon]. [/ccon].
Please review the error message and provider documentation for further information and corrective action.
Table: Fact.
What error code and message are shown on Bridge Online Monitoring?
Power BI it’s own error reporting typically “eats” the actual error.
As for the last 2 weeks, the same error itgenboe367.
Request ID 0HN2MVV4NO43I:00000035.
itgenboe367
The data download was cancelled straight away after requested.
Please try again.
Contact Invantive Support when this problem persists. (/).
Given the persistent nature of this problem among a subset of users and the extremely annoying impact upon occurrence, progress for this problem will be tracked at Problemen bij geannuleerde downloads en/of downloads die blijven hangen (Dutch).
It will be treated as the highest priority until the probability of occurrence is significantly reduced.
Via the “bell” on the linked article, you can subscribe there to automatically receive any updates.
