Simplicate Employee response does not contain list of teams
We are using the Simplicate integration to fetch employee data.
The Simplicate API endpoint exposes an array of teams the employee is part of.
This data is not available when querying the HRM.Employees “table”.
Is there some other way to access the list of teams an employee is part of?
Does the following link provide guidance?
When not, please add an (anonymized) screenshot and/or a link to the API documentation regaring “array of teams the employee is part of”.
Thanks for the suggestion, tablefunction TeamPersons does not return any results.
It look’s like the API documentation of simplicate does not include the list of teams on person level but the response does. After reading some other forum posts my conclusion is that the integration only returns data thats part of the specification.
For now I’m fine with determining the team/company based on e-mailaddress
Thanks for the update.
Yes, the SImplicate driver follows the Open API specification published by Simplicate. It is known that Simplicate does not or only limitedly maintains the specifications, leaving room for improvement.
As an alternative, the Simplicate API can also be queried for this data using a view on NativePlatformScalarRequests in combination with JSONTABLE:
For a sample using no driver at all see for example (Dutch):
