The table TransactionLinesIncremental cannot be loaded. See below the screenshot of the query where I am retrieving just 10 rows. I eventually stopped it manually. But it can’t take that long (1,340,206 ms = 22 minutes) to retrieve just 10 rows, can it?
Retrieving 10 rows from an *Incremental table requires the complete construction (initially) and updating of the entire dataset. Invantive Cloud operates on a “pull” basis, not on a “push” basis when refreshing data. For the technical background on the necessity of construction, also see:
The advice is to check in the Session I/O’s screen whether there is any activity. A reasonable estimate for full construction is approximately 5 seconds per 1,000 rows. The number of rows can be estimated using, for example, the RowCounts view:
