More insight with new Online Monitoring
In addition to many new users, Invantive Bridge Online, as part of Invantive Cloud, is also experiencing increasingly intensive use. In the existing Bridge Online Monitoring, it was difficult to keep an overview in large and complex reports due to hundreds of data requests coming in for a series of Power BI reports.
The following improvements are available:
  • All monitoring via Invantive Cloud itself for all servers
  • Simpler display
  • Tooltips on all fields with potentially long texts
  • Detail mode
  • Display of SQL, number of rows, and origin.
Often, the timeline is the most convenient to use:
But the live view and history lists are also handy at times when dealing with older requests. All show the same information.
Just as before, only requests from the current user are visible. Requests from other users, either within one’s organisation or elsewhere, are not visible. When using a separate service account for loading with PowerBI Service, the Online Monitoring should be opened with that service account.
The last two are further explained.
By clicking on a line in the Online Monitoring, the underlying details of the OData request are displayed. At the bottom of the details is a comprehensive list of the steps executed.
In the details and the overview, it is visible whether the data comes from the cache or has been freshly retrieved. The number of rows is also visible; currently only if the data has been freshly retrieved.
The Invantive SQL statement is also visible. In this example, it concerns the unfiltered retrieval of sales invoices from Exact Online:
select t.*
from   ExactOnlineREST.SalesInvoice.SalesInvoicesBulk@eol t
If an OData filter is sent along from Power BI, this will be visible as a where clause. This helps to analyse whether Power BI is correctly sending OData filters along or rather leaving the evaluation mostly on the PC. The latter sometimes takes significantly longer.
The by far most common problem is time-outs. Power BI uses a default timeout of 10 minutes while many users have hefty real-time queries that last longer than 10 minutes. Solutions for a time-out are available at Vermijd time-out fout bij Power BI OData download. Solutions for other common issues are described in Wat zijn de aandachtspunten om Power BI te implementeren?.
Origin of Queries
At the bottom of the details, the so-called “HTTP headers” of both the request and response are visible, including the “User-Agent”. The User-Agent should reflect the application used.
User-Agent with the content “Microsoft.Data.Mashup” is Microsoft Power BI.
It is advisable to add your own HTTP header with a traceable value to, for instance, Azure Data Factory pipelines to minimise the problem of not being able to trace the origin of the OData queries. A step-by-step guide for making downloads traceable can be read at OData downloads herleiden naar Power BI data sets.
Problem: Online Monitoring shows no download requests
Monitoring only shows requests from the current user. Requests from other users, even within the same organisation, are NOT shown. To solve this: ensure that the download requests from, for example, Power BI are authenticated with the same user as the one used to log in to Invantive Bridge Online Monitoring.
Update August 2026
The situation of Online Monitoring has been updated because the functionality has improved compared to 2021.
Itgeneor229 Er is geen capaciteit meer beschikbaar voor API-gebruik op partitie '2628...'
Itgenboe147 bij ophalen gegevens uit Simplicate
Niet opladen van gegevens uit de Cloud
Itgenoda316 Timeout bij ophalen gegevens via Invantive Cloud
Melding ophalen gegevens
Fout ophalen gegevens naar Power BI via OData feed na honderden megabytes
Invantive server wordt niet bereikt?
Exact_TransactionsLines blijft ergens op hangen?
Limieten Dataverlading in Azure Data Factory
(429) Too Many Requests. (Too Many Requests)
Dashboard Exact Online x Power BI refresht niet
Kan data uit Exact Online niet laden in Power BI
Power BI melding Teamleader bij download: De onderliggende verbinding is gesloten; bij ontvangst is er een onverwachte fout opgetreden
OData: Request failed: The operation has timed out
Server error bij ophalen data uit Odoo
Automatisch verversen PowerBI geeft: "An existing connection was forcible closed by the remote host"
Telkens ander IP adres bij geplande verversing app.powerbi.com
Bridge Online cache moet eerst geleegd worden voordat PowerBi nieuwe date ophaalt
Odoo v16 : Interne serverfout - itgenodo096: keys must be str, int, float, bool or None, not frozendict (200) (builtins.TypeError)
Power BI: "Het laden wordt geblokkeerd door fouten in andere query's"
Duur verversen Power BI service varieert sterk
Foutmelding in verbinding: De onderliggende verbinding is gesloten
Binnenhalen artikelvoorraden in Excel Power Query
Azure Data Factory: Cannot write more bytes to the buffer than the configured maximum buffer size: 2147483647
ODATA Bouw7 datums staan op één dag eerder
Exact Online verversen vanaf Desktop gaat goed, maar vanuit Power Service niet
ExactOnlineREST.Incremental.TransactionLinesIncremental@EOL geeft "Too many rows"
OData: Request failed: The remote server returned an error: Too Many Requests
Power BI downloads vanuit Twinfield, Exact Online en anderen vlot afbreken
Power BI - TeamLeader - query wordt tweemaal uitgevoerd
Prestatieproblemen bij het ophalen van de Teamleader data via SQL Server
Probleem inlezen data Exact Online in Power BI [DataSource.Error]
502 Bad Gateway fout bij Power BI refresh via Bridge Online - Exact Online
OData request faalt vanuit Power BI - B4FA1F - itgenclr003
Volledigheid SalesInvoices / SalesInvoiceLines
Correctie maximum aantal parallelle downloads
OData - Bridge-online.cloud doet het niet meer met Power BI: itgenboe161
Itgenoda359 Refresh data afgebroken
Uren inladen vanuit Simplicate loopt vast Microsoft.Mashup.Evaluator.Interface.ErrorException
Dataflow transaction lines werkt niet
DataSource.Error: OData: Request failed: The underlying connection was closed: An unexpected error occurred on a receive
Error in reloading: An existing connection was forcibly closed by the remote host
Twinfield database ververst niet: itgentfr091 op TimeAndExpensesDetails
Transacties afgeletterd / Matched binnen grootboekrekening
Samenvattend overzicht gebruik Bridge en App Online door organisatie
500 error PowerBi - Exact online
Power BI refresh via Invantive Bridge Online op Loket.nl
Foutmelding Twinfield laden in Power BI
Twinfield / Power BI error: Request failed in Power BI navigator
Koppeling Invantive-PowerBI (Twinfield administraties)
DealWithActivities melding Invalid JSON
Hoe los ik een itgenrst013 error op voor datums voor de start van de Gregoriaanse kalender?
Foutmelding interne serverfout (500)
Itgenxml091 foutmelding bij het querien op NMBRS.EmployeeContracts
OData: Invalid JSON op Exact Online InvoiceTerms
Power BI laad enkel 1 van de 4 administratie in uit Exact Online
Foutmelding bij refreshen in PowerBI: Information is needed in order to combine data
Problemen ophalen tabel ExactOnlineREST.Incremental.TransactionLinesIncremental@eol
Itgenboe147 melding
Time-out bij het inlezen van TeamLeader tabel `Teamleader.V2Flat.InvoiceLinesAll` in PowerBI (itgenboe070)
OData Exact Online filter performance
Exact Online downloaden lukt niet: De geplande vernieuwing is uitgeschakeld omdat in ten minste één gegevensbron de referenties ontbreken
Verversen van IncrementalAccounts tabel uit exact loopt vast
Dashboard refresh: data van na week 15 niet beschikbaar na verversen
Financial ReceivablesList@eol niet up-to-date
Verminder hoeveelheid data en verbeter de prestaties van uw Power BI-rapport door te filteren
"Unable to read data" bij het laden van Exact Online data
OData feed Exact Online naar PowerQuery in Excel
Foutmelding Exact Online transacties
The remote server returned an error: (500) Internal Server bij Teamleader en Exact
Itgeneor680 Twinfield databases error
Geen verbinding vanuit PowerBi: Kan niet verifiëren met de opgegeven referenties
Activeren nieuwe versie view in Bridge Online
DataSource.Error: OData: Invalid JSON. A comma character ',' was expected in scope 'Array'. Every two elements in an array and properties of an object must be separated by commas
Authenticatie error OData-feed Exact Online
Exact Online Sales Orders Incremental - geen data
Visma.net Power BI download Dimensions geeft: A comma character ',' was expected in scope 'Array'
Balans per periode van kostenplaats en grootboekrekening?
Foutmelding bij ophalen Odata gegevens in PowerQuery
Meerdere relaties uit Exact Online in Tableau met dezelfde naam, maar andere code
Fout in de gegevensbron: The 'project_purchase_order_number' column does not exist in the rowset
OData niet vernieuwen
Itgenhhr017 AWS-server geblokkeerd voor finder.asmx
Exact Online - Power BI refresh blijft hangen of duurt erg lang
Mashup.ErrorCode 10122 - HTTP 500 bij OData refresh via Invantive Bridge Online (Exact Online koppeling)
Relatieclassificatie voor o.a. marktsegment wordt niet gevuld met waarde
PowerBI.com Service OData-download issue: "An existing connection was forcibly closed by the remote host."
Visma.net ERP view JournalTransactionLines leeg bij ophalen in Power BI
Itgenhhr017 Twinfield data worden niet vernieuwd
Foutmelding laden Exact Online Power BI
Vernieuwen Data Power BI: forcibly closed by the remote host (raised by the IDataReader interface)
Power BI rapport kan niet meer gerefreshed worden
Twinfield.Dimenions.Customers geeft Invalid JSON. A comma character ‘,’ was expected in scope ‘Array’
Foutmelding - itgenoda359 op Gripp
ItemsIncremental geen vernieuwing?
Tabel uit AFAS heeft soms geen data
Itgenoda330 for ContractLinesHistories
Mollie data ververst niet
Headers toevoegen aan Power BI data sets via OData
Error bij het laden van data in Power BI Service
Teamleader performance
Problemen met ophalen en inladen data tabel: "FixedHourComponents@nms"
Externe server fout
Geen nieuwe data in PowerBI
Herladen in Power BI Service met Gateway connectie geeft "A comma character ',' was expected in scope 'Array'"
Snelstart Relaties itgenjuy020
Easyflex - database melding itgenefx025
Verversen in power bi service gaat fout: Cannot find table ReportingBalance
Foutmelding Invalid JSON bij tabel CustomerPaymentLines@vnt van Visma.net Financials
Itgenboe406 error Message when refresh
Failed to create OData connection to RequestUrl
DataSource.Error: OData: Request failed: The remote server returned an error: (429) Too Many Requests
Easyflex gegevens worden deels niet meegenomen in verversing
Refresh in Power BI Services
Vernieuwen PBI werkt niet, statuscode 500, Odata werkt wel
Too Many Requests Snelstart
Itgenboe242 bij navigatie
Databasesegment bestaat niet
Power BI report refresh error (Twinfield)
Vastlopen download transactionlinesbulk
Download data geeft "[DataSource.Error] OData: Unable to read data" in Power Query
Data niet compleet
Geannuleerde downloads
Foutmelding itgenboe031 bij inladen gegevens
Melding Odoo bij inlezen: Failed to save modifications to the server
Fair Use Daglimieten voor een Betere Gebruikerservaring
Foutmelding PowerBI bij vernieuwen
PowerBI fout met laden gegevens: A comma character ‘,’ was expected in scope ‘Array’
Odoo foutmelding refresh
Itgenclr009 Microsoft.OData.Core.ODataException,Message=Invalid JSON. Unexpected end of input was found in JSON content
Foutmelding bij CRM tabel `Accounts` in Power BI
Foutcode itgenclr093
SalesInvoice tabellen error via OData Azure Data Factory
Itgencmi027 Request aborted by server crash or alike
Dataflow-synchronisatie mislukt door veranderende Bridge Online verbinding
OData connector kopieert records ipv updaten in Power Apps
Foutmelding "De sleutel komt met geen enkele rij in de tabel overeen." na migratie van Exact Professional naar Premium
"Deze pagina werkt momenteel niet" HTTP ERROR 401 bij openen https://bridge-online.cloud/monitoring
Koppelen Power BI aan Exact Online geeft HTTP 500 Interne serverfout
Laden OData Exact werkt niet online
Geen connectie meer met TransactionLines
Itgenoda345 - Operation time outs bij Teamleader verbinding
Itgenboe680: Verbindingsfout GRIPP België
EmployeeEmployments, EmployerEmployees: itgenodr007 travel_travelDistanceToWorkInKm
Download faalt met onbekende foutcode sinds 16/03/2024
Bijwerken artikelen in Exact Online vanuit Excel-bestand met curl
Gebruik Power Automate met Exact Online
PowerBI blijft op vernieuwen hangen
The remote server returned an error: (503) Server Unavailable
Authenticatiegegevens AFAS onjuist (itgenoda220)
Vraag datum/tijd filters: 1 uur verschil tussen Power BI filter en datum/tijd in Bridge Online Monitoring
Storing bij ophalen Loket tabellen
The daily limit of 5,000 fresh API rows has been exceeded by 149,367
Request failed: OData Version: 4, Error
Too Many Requests op SnelStart
Itgenboe562: Invalid credentials and error 500
Describe_entities en read_records geven fout na toevoegen database-url-segment
JSON array not valid
Volledig herladen TransactionLinesIncremental
ExactOnlineREST.SalesOrder.SalesOrders@eol werkt niet via Azure Data Factory
HTTP 500 AFAS profit_salesorders: itgenaoe027
OLE DB or ODBC error + internal server error na reparatie database voor PowerBI
Unable to connect to the remote server
Simplicate uren eindigt vroegtijdig bij 64.174 rijen met itgenboe161
PowerBI : DataSource.Error: OData: Unable to read data from the transport connection
Itgenboe161/ itgenboe241 - De gegevensdownload werd geannuleerd na
Datacontainer needs to be repaired (itgenscr652)
JSON string value Fout bij vernieuwing: Unexpected end of input reached while processing a JSON string value
Automatische refresh dataflow faalt met GatewayUnreachableException
Status code 500
Loket data offline: the driver has run out
PowerBI Desktop wil niet meer refreshen na update
Error OData verbinding Exact Online
Itgenoda126 bij opbouwen Teamleader Focus connectie
Itgensgr134 Repeating cache key
Too many requests (429)
Schema importeren Azure
Sync tussen Power BI en Exact Online foutmelding - gestopt sinds 23-12
Error OData PowerBI Exact Online
Problemen inladen Exact-online naar Power BI
DimGrootboekrekeningen geeft "The remote server returned an error"
Itgenboe161 bij ophalen TransactionLines
The credentials provided for the OData source are invalid
Generieke Power BI fout
Dagelijks opnieuw aanmelden PowerBI & Invantive Bridge
Handmatig laden van Exact Online TransactionLines in PowerBI lukt niet
OData request failed - HTTP 429
Koppeling Loket offline
Onbekende error in Power BI Dataflow
Azure Data Factory - Failed to create ODATA connection
Problemen Invantive Cloud
Details: "Microsoft.Mashup.Engine1.Library.Resources.HttpResource: Request failed:
Itgenscr817 Het laatste actieve abonnement … van … is 28 dagen geleden afgelopen
Foutmelding bij het aanroepen van een database: itgenscr811
Exact Online grote datasets
Unable to update connection credentials
Invantive Bridge online server error & bridge online monitor not working
PjtTimeTransactionsIncremental blijft eindeloos hangen
Internal server error & bridge online monitoring issues
Exact database niet bijgewerkt
Internal server error bij ophalen data uit SnelStart
Foutmelding bij inlezen Exact in Power BI
ADF loopt sinds enige tijd standaard stuk met itgenboe403
Fout verversen Table: Exact Online GLAccounts
Problemen met de connectie
Itgendvr055 time out melding, ook op kleine data set
Bij het importeren van de data in Power BI komt niet de nieuwste data naar voren
Incrementaal laden
Lange laadtijd voor grootboek in Visma Net
Geen connectie meer Freshdesk (itgenfpr045)
Exact Online refresh: An existing connection was forcibly closed by the remote host
Itgenclr150 foutmelding refresh Power BI Teamleader
Issue Incremental.TimeCostTransactionsIncremental@eol
Itgendcr004 ophalen Teamleader Focus data Power BI
Itgenahr129 Unauthorized
Tabel DataDictionary.Custom.GENERALLEDGERBALANCESALL bestaat niet meer
Onmogelijk om Exact Online tabel (TransactionLinesIncremental) te verversen in Power BI
Issues laden Exact Online-data dagelijks naar Power BI
Itgenlic754 refresh error Exact Online
Itgenclr019 bij Wisselkoers invoer TRY
Automatische PowerBI.com refreshes Nmbrs mislukken
Exact Online GoodsDeliveryLinesIncremental itgeneor643
Itgenaoe027 error bij ophalen profit_debtor
Uren Simplicate geeft "Cannot convert the literal ... to the expected type 'Edm.DateTimeOffset'
Itgenjuy027 foutmelding bij het opvragen van InvoicesLastTwoYearsAll
Ophalen ExactOnlineREST.Financial.ReportingBalance lijkt te hangen
Exact Online in Power BI: The credentials provided for the OData source are invalid
OData4 verbinding lukt niet door error itgenlic727
Mijn gegevens worden niet goed vernieuwd
Itgentlr015 Teamleader.V2Flat.TimeTrackingAll@tlr
Exact Online verversing ExactOnlineREST.Incremental.GoodsDeliveryLinesIncremental@eol werkt niet meer
Problemen bij verversen van Teamleader en Twinfield data
Account move line wil niet laden via ODOO API
ProfitLossOverview mist data
Itgenoda316 time-out bij ophalen van AFAS-data is overgang Profit 5 naar Profit 6
500 Internal server error
PowerBI - OLE-DB ODBC-fout HTTP 500 Interne serverfout
HTTP 503 Service unavailable error: TransactionLinesIncremental Azure Data Factory
Consistente error bij vernieuwen Nmbrs-tabel EmployeeCostCentersCurrent@nms
Itgenwed002 geo/IP-block
Verversen PowerBI foutmelding: 503 Server Unavailable
Autotask data laadt niet meer
OData-feed werkt niet of is heel heel langzaam in ieder geval onwerkbaar
Itgenoda048 Toegang tot de OAuth-gegevensbron vereist een geldig access token. Het access token kon niet worden verkregen
Itgenboe161: De gegevensdownload werd geannuleerd na 5 minuten, 0 seconden, waarschijnlijk door de gebruiker
Teamleader Focus query wordt na precies 5.00 minuten afgebroken
Itgenlic727 Het abonnement ‘SUBFPALL’ van ‘…’ geeft geen toegang tot Exact Online abonnementen van ondernemers zoals ‘…’
Power BI connection Nmbrs geeft: Onverwachte fout: Kan Bytes [8B] bij index 1 niet omzetten van opgegeven codetabel naar Unicode
Downloads Invantive Cloud blijven hangen
Power BI error message Invaid JSON
Itgenclr075 bij poging tot benaderen Simplicate
Boekingsregels komen niet meer door
Twinfield itgentfr092: Toegang geweigerd. Company ontbreekt in request header (NLLEEG)
ExactOnlineREST.GeneralJournalEntry.GeneralJournalEntryLines laad niet
Error 500 bij verbinden Power Query met Exact Online door middel van OData
Twinfield: Twinfield.Views.GeneralLedgerAccountMappingAccounts@tfd
Verversen van de gegevens in Power BI duurt eindeloos
Unable to translate bytes [8B] at index 1 from specified code page to Unicode
Problemen met ExactOnlineREST.Financial.ReportingBalance@eol_table
Snelstart fails to get new data
Externe serverfout in Power BI. Geen problemen in Bridge Online
Snelstart laden in Power BI
ExactOnlineREST.Incremental.TransactionLinesIncremental@eol TimeOut in Data Factory
Hoe nog efficienter maken Exact TransactionLines?!
NMBRS - loonjournaalpost HeaderDate
Exact Online: itgensql035 & Onbekende ID \u0027CFD.ID\u0027. Overweeg een van de volgende: ID, Modified
Itgenoda220: melding bij ophalen SnelStart grootboekmutaties
Visma.net reports failing during refresh with OData errors
Foutmelding itgenscr754
Conflicteert real-time data ophalen met beperkte API limieten?
Performance Exact Online API
Exact > PowerBI: 500 Internal Server Error
Itgenmcp447 MCP failed connect to Claude
Odoo: Account.Move_Line heeft enkel kolommen, geen rijen
VismaNet.Views.JournalTransactionLines@vnt table not working
Ontbrekende velden purchase_price en margin voor sales order line in Odoo
Semantisch model PowerBI geeft foutmelding time-out
Foutmeldingen bij vernieuwen in Power BI service
PowerBI refresh via Invantive Bridge gaat fout
Verversen nmbrs_costs lukt niet meer
Foutmeldingen bij verversen "CompanyRunCostCentersV2@nms"
Itgenmcp446 and itgenmcp667 for connector MCP
Verversen Exact Online duurt lang
Code 429: Too many requests
Bouw7 Athena API security codes per kostensoort
Odoo foutmelding bij inladen tabel: Kan bytes [8B] bij index 1 niet omzetten van opgegeven codetabel naar Unicode
Deel administraties in Exact Online niet benaderbaar
Storing ExactOnlineXML.XML.APOutstandingItems@eol
TransactionLinesBulk@eol geeft: Unable to translate bytes [8B] at index 1 from specified code page to Unicode
Itgenclr150 + itgendcr031 bij verversen gegevens
Foutcode itgenoda042
Odoo.res.partner@odo geeft error
Twinfield-gegevens zijn erg traag of blijven hangen bij het vernieuwen van Power BI
Terugkerende foutmelding autorisatie datacontainer Exact Online
Geheugenfout - kan niet opslaan op server
Mashup errorcode 10122
Custom views niet beschikbaar in Power BI
Itgenedm071 HTTP 500 Internal Server Error – Fortnox / Invantive Bridge Online
Storing bij ophalen Loket data
Trage performance en time-out
Tabel openstaande posten Exact Online per peildatum
Itgenboe242 melding bij verbinding met JIRA error code (HTTP 499)
Itgeneor795: corrupte incremental cache AccountsIncremental
Geleidelijke verlaging van Exact Online API-limieten leidt tot "Too many requests" en itgeneor229 of itgenexl150 foutmeldingen
Exact Online tabellen worden niet geladen
Gemakkelijker OData downloads analyseren met Bridge Online Monitoring
De externe server heeft een fout geretourneerd: (499). itgenboe242
Ik merk dat jullie aanpassingen gedaan hebben aan de monitoring maar die is hierdoor helaas een pak minder leesbaar geworden. Vooral het “pad” zorgt voor problemen - zie voorbeeld.
E.e.a. is inmiddels verder verbeterd qua indeling. Hopelijk is zo weer beter bruikbaar.
Een bericht is gesplitst naar een nieuw topic: Bridge Online Monitoring app laadt niet
